Header install Question
Old Feb 18, 2006 | 12:16 PM
jblackbird's Avatar
Default Header install Question
I'm installing the pacesetter LT, I got the driverside manifold out and all the the passenger bolts out, the problem I have now is the dipstick is routed through the manifold, how do I remove the dipstick? I took the 15mm bolt out that mounted it to the engine block already. do I just pull on the dip stick to get it out?
Old Feb 18, 2006 | 12:18 PM
WildRon's Avatar
just pull up on it
Old Feb 18, 2006 | 12:24 PM
jblackbird's Avatar
Thanks wildron, manifold out
Old Feb 18, 2006 | 01:54 PM
NassyVette's Avatar
Getting it back in is the fun part
Old Feb 18, 2006 | 03:34 PM
lgobraves's Avatar
its not bad at all esp if you have a friend helping
