Fast idle on new BBK throttle body
Old Feb 18, 2006 | 12:37 PM
graynor's Avatar
Default Fast idle on new BBK throttle body
We just bolted on a new bbk throttle body with new intake manifold. It idels fast and is slow to idel back. Are there any adjustments .
This is on a 00 formula ls1.
Many thanks
graynor
Old Feb 19, 2006 | 10:31 AM
WILWAXU's Avatar
to the top
Old Feb 19, 2006 | 11:56 AM
Firehawk441's Avatar
I'm sure Nine Ball can help!
Old Feb 20, 2006 | 07:10 PM
Modern_Muscle_Man's Avatar
I just did the same thing today. It only searched for an idle for the first couple of minutes as it said it would in the instuctions. Once it settled in I took it out for a drive and everything is great. Very punchy right off the line, and seemed to lose a little in the mid range, but up top it really sings. It's so punchy in fact that when I got off the freeway to turn around I left the light turning left and it actually kicked the *** end of the car around. Was fun but really suprised me as I didn't give it much throttle. Check and make sure you don't have any vacuum leaks. Did you transfer the o-ring on the IAC? If not that is most likely your problem. I almost missed it too. Good luck and enjoy.
