LM question
Old Feb 21, 2006 | 04:06 PM
gyrene2003's Avatar
Default LM question
ok, installed my loudmouth about a week and a half ago and i noticed my gas milage has gone down dramatically, do i need to do something to my computer or is this normal? i was expecting some loss but this seems like more than normal! thnx
Old Feb 21, 2006 | 04:22 PM
LiquidFire350's Avatar
a slight decrease is expected untill the computer relearns, but that should only take a couple start-ups, 200 miles at most
are you sure your not flooring it more because of the sound, that would cause a gas milage decrease
is there anything else you did, and did you put it on yourself?
Old Feb 21, 2006 | 04:27 PM
gyrene2003's Avatar
well of course i took it out after-words and wanted to here it, and yes i did put it on myself, but i did it with a fellow f-body owner and former mechanic who also has the same exhaust so im sure its set up correctly. the thing about it is, im in the Marine Corps. and i did it on base at the hobby shop and i live on base so its not that far of a drive anywhere for me! He had mentioned pulling a wire or something i dont remeber, to resert the computer.
Old Feb 21, 2006 | 04:28 PM
gyrene2003's Avatar
thats all i did by the way. thats also my only real performance upgrade!
Old Feb 21, 2006 | 04:38 PM
98Z28MASS's Avatar
Lead foot syndrome...
Old Feb 21, 2006 | 04:45 PM
2K2WS6TA's Avatar
You're probably putting your foot into it more, just because you want to hear the new sound, I did the same thing The first week I had my exhaust I lost about 2 mpg.
Give it week for you to get used to the sound, and it'll likely go back to what it was.
If you really want to reset the computer, disconnect the negative battery cable, be aware the car may idle funny till the computer relearns all the idle settings, if you want the complete process for resetting the computer, search for the term "idle relearn"
Old Feb 21, 2006 | 06:22 PM
honestly, dont touch the computer, it will adapt the the changes youve made on its own, just let it run its course
Old Feb 21, 2006 | 09:17 PM
SSHADOW's Avatar
After I installed my TSP Rumbler my mileage went down a little bit. But I attributed that to I was in the gas I a little more, cause I liked the sound. After A couple of weeks it kinda wore off and my mileage got better than before the exhausty by 2 mpg.
Semper Fi
Eric
 Michael S. Palmer
Old Feb 22, 2006 | 12:38 AM
Xx01CamaroZ28xX's Avatar
I think the only reason youre getting worse gas mileage is because you like how much better it sounds, so you tend to stomp your right foot a little more.
Old Feb 22, 2006 | 07:14 PM
MONG00SE's Avatar
Yeah, technically any bolt on should either maintain gas mileage or improve it. Power adders are what really kill the mileage.
Old Feb 22, 2006 | 07:23 PM
nokeman's Avatar
HAHA Ive had my car for almost a year and I still get on it because of the way it sounds. My MPG sucks on the city.
Old Feb 24, 2006 | 09:37 PM
Yeah, the reason your gas mileage is staring to suck now is due to the new syndrome in your right foot called lead foot syndrome, its non treatable and you will probably have it for the rest of your life. I know I got it when I got my LM exhaust.
