best intake......
Food for thought
It will be about 3 weeks or so until I get my car up and running.
BTW, I haven't rerouted my coolant lines passing through the TB either... yet.
Marc
i hear what some of you guys are sayin about how some of these intakes are sucking in hot underhood air but im not sure if that is such an issue since the vehicle is in forward motion there would be alot of cooler fresh air coming into the path of the intake and engine compartment and that is where i got the idea of cutting an opening in the sheat metal under the filter on the FIPK where the slp cai used to be.
Marc
Check out www.installuniversity.com for their testing on the FTRA. They had an 11 degree drop in IAT temps with the FTRA installed. Ignoring the other benefits of the FTRA, an 11 degree F drop in intake temps results in 1 % more power. Now add is the increase in VE and fuel economy and I think you will see why the system is so popular
It's on sale for 159.99 right now by the way
For the best performance, you do need an aftermarket lid. A smooth bellows and ported TB will work well with the system as well.
Make SURE you have a positive seal for the best performance. Most people forget this step and they are leaving a lot of HP on the table.
Edit: Nevermind. I see that the tests were done with the car moving. Pretty cool (no pun intended).
On a side note, the ram air kit also cools off the IAT temps faster when the car goes from sitting to moving than the factory set up, free cold air mod and SLP set up.
Great point. My IAT's are +- 2*F of ambeint at speeds > 30mph with the Volant (dual cone w/ gutted WS6 hood). Somehow I missed the FTRA when I was looking for an intake. Would have given it a shot had I found it then.
How do you go about thoroughly testing for a positve seal?
The car does not pull nearly as hard in 3rd or 4th. I have an SS, so what little ram air I had is completely gone and I could tell right away. The car used to be a beast in 3rd and 4th...not anymore.
The only advantages I can say about it are it feels a little stronger in 1st and 2nd (which usually go up in smoke anyways) and you get the cool open intake sound.
If I could do it over, I would have just gotten a lid.
Like somone mentioned before, I plan on cutting out a big chunk of the metal panel under the filter, that might help a little, maybe even see if I can rig some type of ram air into it.
But like others have said, the fact that it is not sealed, I think is a problem.
k&N FIPK all the way!!!!
my lil' LT1
