Pinning Damper to Crankshaft
Old Feb 24, 2006 | 03:13 PM
Hodge's Avatar
Default Pinning Damper to Crankshaft
Is there any benefit to pinning the damper to the crank on a normally aspired LSx? I'm pulling the engine out of my C5 this weekend and that would be the time to do it. My new setup is heads and cam. Nothing I would consider radical. Thanks in advance.
Old Feb 24, 2006 | 08:26 PM
ss rally red's Avatar
My thought are if GM thought it unessecary.......
Old Feb 24, 2006 | 11:03 PM
Zeus's Avatar
I know this doesn't answer your question, but how do you go about doing this? Is it as it sounds, where you drill holes through the snout/pulley and put pins in, or is there more to it?
Old Feb 25, 2006 | 09:06 AM
BOTTLE ROCKET's Avatar
Cheap insurance!!
I had a cam change done in my C5 about a year ago and "apparently" the crank bolt wasn't torqued quite tight enough. I was on a dyno about a month ago, doing a run, when a "puff of smoke" came out of the engine and we shut down. After inspection, we found the bolt backed out and the crank had eased off about 1/4". It threw the belts and dumped oil on the floor. I have now got to go back in and spend time and money on a new balancer, gaskets, seals and fluids, and oh...I WILL pin the crank this time!! (The C5 has to have the steering rack removed)
Compare that to the fact that I borrowed a pinning tool from a forum member ($10 shipping both ways) and a steel pin cost $1.10. It takes about 20min from start to finish to do.
Like I said..cheap insurance
Old Feb 25, 2006 | 10:29 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Pin it, but only if you are thinking about a supercharger down the road. If not do not bother. I had mine pinned when I upped the boost from 5 to 10 PSI.
