starter!!!!
Old Feb 25, 2006 | 02:29 PM
ubnsmkd03's Avatar
Default starter!!!!
stupid ? but where is the starter located.... iam starting my car for first tim all winter and i think from sitting starter went bad so i want ti bang on it see if it starts cause i jumped car and it just clicks and as soon as i discconect cables it's dead again... any help would be greatly appreciated...
Old Feb 25, 2006 | 03:31 PM
Detroitmuscle's Avatar
The starter is located under the passneger side just behind the exhaust manifolds and right next to where the trans mounts up to the block. You will have to remove the rock-plate on that side to drop it down too. Its only held on by two 15mm bolts and has three connections that go to the top of it, but make sure you disconnect the battery first and don't shock yourself lol.
Old Feb 25, 2006 | 03:36 PM
ubnsmkd03's Avatar
lol thanks i had a felling it was barried... appreciate it
