how much material to remove from TB
Old Feb 25, 2006 | 02:54 PM
98RedBird's Avatar
Default how much material to remove from TB
How much material do you guys remove when you port your TB? thanks!
Old Feb 25, 2006 | 04:21 PM
Bo White's Avatar
From about 2-3mm from the blade all the way back to the entrance is completely reshaped. I have often wondered how many CCs were removed myself, guess Ill have to do that someday. The amount I wouldnt know, I go by feel and that is hard to pass on.
Old Feb 25, 2006 | 04:24 PM
ShevrolayZ28's Avatar
There's also a good TB porting instructional in the sticky at the top of this subforum.
Old Feb 25, 2006 | 07:31 PM
JonB's Avatar
It seems like alot when your doing it. I went back and did mine 3 times i would spend some time on it and after I was done and had it back on I felt like I could take more which I could. Eventually I made a small hole on the side thats when I relized I had went to far and finally stoped.
Old Feb 26, 2006 | 07:21 PM
WILWAXU's Avatar
Checkout page #2
https://ls1tech.com/forums/showthread.php?t=139142
