TSP catted y pipe
Old Feb 26, 2006 | 12:26 PM
ryanfx's Avatar
Default TSP catted y pipe
Does anyone know exactly how much lower this hangs? Clearance is a big issue for me, and I have about an inch and a half of clearance getting out of my driveway from my stock y-pipe.
Also, while i'm doing a header install, is there anything else I should worry about? How long do the poly engine mounts take? I hear they are a good thing to do while you are doing the headers to prevent the y-pipe from banging against the floorboard. Would the mufflex bump stop work just as well?
Old Feb 26, 2006 | 01:50 PM
T/AFOSTERWS6's Avatar
THE TSP CATTED Y-PIPE WORKS WELL PULLING WEEDS OUT OF MY DRIVEWAY, MY ADVISE IS TO LOOK ELSEWHERE, I AM. If I didnt worry so much about rasp I would try a reg ORY. I have had my TSP installed for over 6months, I have it adjusted for max clearance and only have around 3 inches off the ground. stock height ws6
Old Feb 26, 2006 | 02:55 PM
ryanfx's Avatar
how much difference is it over stock?
Old Feb 26, 2006 | 04:41 PM
Its alot lower on the driver side
Old Feb 26, 2006 | 06:37 PM
slow trap's Avatar
the driver side will probably only be around 3 inches off the ground at best.look elsewhere for ground clearance.
Old Feb 26, 2006 | 06:44 PM
ryanfx's Avatar
3 inches after the fact that my car is lowered?
