no power steering
Old Feb 26, 2006 | 02:39 PM
TRANSAM_2000's Avatar
Default no power steering
Hey, I have 2000 TA m6. I was racing by friends 01 Z28 A4 after we was done i didnt have any power steering we got home and we looked and the belt wasnt broke nothing came loose.Would the steering box be bad or the pump please help. by the way i won .
Old Feb 26, 2006 | 02:59 PM
LoudmouthLT1's Avatar
Well first thing you need to do is look to see if theres a leak, you may have just blown a line off.
Old Feb 26, 2006 | 03:09 PM
no leaks line look good
Old Feb 26, 2006 | 05:44 PM
NexGen's Avatar
take the belt loose and pull on the pulley, is the shaft broken. thats what happened to mine recently.
Old Feb 26, 2006 | 06:56 PM
BlutVonSchwachen's Avatar
Not to be rude, but did you check for fluid in the pump first of all? Any sounds coming from the pump (more noticeable when the wheel is being turned)?
Old Feb 26, 2006 | 07:04 PM
yes it does have fluid. the pully turns with the belt on so i dont know if anything is broken and what do you mean shaft is broken
Old Feb 26, 2006 | 07:06 PM
so what could be wrong pump or steering box or rack no noise
