my vic jr conversion pics/thoughts
Old Mar 3, 2006 | 10:04 AM
BLWN1's Avatar
Does the flat TB use all stock style connectors/harness or would I have to modify anything to make it work? I like that idea for clearance issue I see coming up..
Old Mar 3, 2006 | 10:09 AM
peterock98's Avatar
Looks good!
Old Mar 3, 2006 | 10:14 AM
02Z28's Avatar
Looks good! Can't wait to see it run on the 11th
Old Mar 3, 2006 | 12:53 PM
ataylors's Avatar
that pro flow air filter will cost you atleast 20hp, ditch it if you can.
Old Mar 5, 2006 | 08:43 AM
jurisz28's Avatar
I won't be running a filter on the track.
Old Mar 5, 2006 | 08:49 AM
383ss's Avatar
yes, it comes with GM IAC and TPS sensors, they just plug right in. I modified the wiring harness slightly to make them reach. very easy to do.
that's only for the street will not be on at the track. I will run with it on and off when I dyno it just for the hell of it. speaking of which, i was supposed to dyno yesterday, but the weather didn't cooperate. I will try to dyno early this week.
Old Mar 12, 2006 | 12:02 AM
383ss's Avatar
FYI after about 10 passes at the track, the fuel rails have worked their way loose. definitely locktite them and make sure they are tight!!
Old Mar 12, 2006 | 07:46 AM
Patrick G's Avatar
LS1 Tech Administrator
So you've already run 10 passes at the track? How are your ETs? If you decreased your ET, you'll be the first I've seen. Everybody else who's tried the single planes have ET'd slower.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 12, 2006 | 08:11 AM
383ss's Avatar
yes, I've ran 10 or 12. I've been working out a lot of tuning and chassis bugs, and still have some to work out. I did run a new best yesterday by a few thousandths, with a worse 60'. 1.45 vs 1.50 yesterday.
it looks like it is going to be a wash over the fast 90/90. that MAY be an issue with my heads though, they just don't seem to want to make any more power.
I have not seen anyone post that they lost ET can you show me the threads please?
Old Mar 12, 2006 | 12:12 PM
MOTRUBL's Avatar
Looks great John.
Old Mar 18, 2006 | 06:16 PM
383ss's Avatar
changed out the air intake
Old Mar 18, 2006 | 06:24 PM
  #32
Cheatin' Chad's Avatar
Looks great!
Can you find another air cleaner? I have seen that type kill numbers on engines before.
Old Mar 18, 2006 | 06:29 PM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd try a pass and without that velocity stack style filter.
Old Mar 18, 2006 | 06:40 PM
  #34
383ss's Avatar
I will NOT run the filter at the track. the main point of it was to pull in cold air instead of pulling in hot air under the hood
as you can see, there is a hole cut in the hood for it
