mounting the FAST 90
Old Feb 28, 2006 | 10:48 PM
SVC707's Avatar
Default mounting the FAST 90
i take it on the longer bolts i wont be needing the silver washers. and the other five bolts are for the tb. the three others im guessing i dont need?
Old Feb 28, 2006 | 11:03 PM
SUX2BU's Avatar
All you need on the long bolts are trhe black washers.
You are right the five smaller bolts are for the TB, two washers and a nut.
The two smallest bolts are for the TB cable bracket, they just need a nut on each one.
The silver screw is if you are still running your EGR.
Old Feb 28, 2006 | 11:07 PM
SVC707's Avatar
ok i forgot about the throttle cable bracket.. and just checked you can use the silver nuts from the longer bolts, i thought i was gonna have to buy some..
thanks
