Installed my motor mounts. (summary inside)
got the car up on jackstands. first thing we seen in the way was the alternator. removed serpentine belt. unhooked battery cable. unbolted the alternator and the bracket. took off the wire and plug on the back of it. put the alternator aside. that pretty much freed up alot of space to work with. then i took a floorjack w/ a small piece of wood on it under the rear of the oil pan. put light pressure on it to support the motor while unbolting the mount. there is 4 13mm bolts holding the mount to the block. we were then able to reach all 4. it took some time and had to use a swivel and extentions on a ratchet, also used a ratcheting closed end wrench on one. (the car does have SLP long tube headers, which did not have much affect on this install) once all 4 of the mount bolts were loosened we removed the large through bolt that goes through the center of the mount. then finished removing the 4 mount to engine block bolts. the mount then slips out of place. drilled all the factory rivets out w/ a 3/8" drill bit. heated the metal shell up w/ a torch, slowly pulled the 2 halves apart. the factory bonding will break free once heated. basically you re-assemble the mount using the new poly mount and the old metal shell. it's all bolted back together w/ new nuts and bolts that come with the mounts. as pictured below.
then you just re-install it all the way it came off. this is where we ran into the time consuming problem. one of the 4 13mm bolts that hold it to the block would not thread in straight. we were afraid it was going to cross-thread into the block. it litterally took 40mins of just messing with the one bolt. finally it went together smoothly and then just slapped the alternator on and belt. started right up. I immediately notice how smooth the engine was at idle. before w/ the mount that was ripped in 1/2 the motor would rock back and forth and almost hit the headers on the steering shaft. took it for a test drive, the car drives smoother and at full throttle shifting it dosen't seem like the motor is gonna fall out anymore! lol. just the driverside seemed to cure all problems i had and i see no reason to ever replace the passenger side mount on my car. i would assume all the TQ is on the driverside mount anyway, with the motor try'n to pull the drivers side upwards at full throttle.
well i'm tired need some sleep. hopefully this will help someone out installing new mounts. hopefully you can understand my tired ramblings. i'm off to bed.
Thanks
Tell you what. I'll ship mine to you next day if you'll send me a 427 in return
EDIT:
I found the prothane ones. Thanks guys.
although I've done them twice on my friends car, still don't like doing it got the car up on jackstands. first thing we seen in the way was the alternator. removed serpentine belt. unhooked battery cable. unbolted the alternator and the bracket. took off the wire and plug on the back of it. put the alternator aside. that pretty much freed up alot of space to work with. then i took a floorjack w/ a small piece of wood on it under the rear of the oil pan. put light pressure on it to support the motor while unbolting the mount. there is 4 13mm bolts holding the mount to the block. we were then able to reach all 4. it took some time and had to use a swivel and extentions on a ratchet, also used a ratcheting closed end wrench on one. (the car does have SLP long tube headers, which did not have much affect on this install) once all 4 of the mount bolts were loosened we removed the large through bolt that goes through the center of the mount. then finished removing the 4 mount to engine block bolts. the mount then slips out of place.[QUOTE=StangEaterSS]
"the mount then slips out of place" WTF am I doing wrong!!?????? I'm attempting to do my prothane mounts and have all 4 mount-engine bolts out, center through bolt out, jack under oilpan, and the damn clamshell is wedged between the k-member mount and the block!! I can wiggle it up and down with my hand but it doesn't have clearance to move up and out!!??? I've tried prying it up and it won't budge past the through bolt mounting point of the k-member mount. Maybe tomorrow I'll loosen up the other sides bolts and see if the engine will raise anymore. I don't want to put too much stress on the oilpan though. Any ideas what I'm doing wrong?
. Now I have to do it with the engine in the car.
