Headers and Ypipe installed but there might be a problem
Old Mar 2, 2006 | 09:22 PM
KilerTA's Avatar
Default Headers and Ypipe installed but there might be a problem
I just put in QTP 1 3/4 headers and QTP Y-Pipe and im checking for leaks ever time i take it out when i look under the car where the collector and the y-pipe meet i see alot of heat moving across the thoses 2 areas on both sides but i feel no air leaking out is this normal also on the driver side header on the #7 clyner it seems to be turing a dark bronze color faster than all the others is that a sign of a possible leak and what is the best way to check for a leak if there is one in the whole system? If you think im freeking out about this to much just tell me and i wont get offended lol
Old Mar 2, 2006 | 09:45 PM
peterock98's Avatar
Easy does it .Drive it for a couple of days and check the header bolts make sure there good.Make sure the clamps are tight.I did not use the clamps that came with it ,I went to napa & brought the 3 inch band clamps.
Old Mar 3, 2006 | 10:02 AM
peterock98's Avatar
The clamps are only 10 bucks each.
Old Mar 3, 2006 | 11:25 AM
KilerTA's Avatar
i use the stanless steel 3 inch band clamps that came with the system
Old Mar 3, 2006 | 01:52 PM
slow trap's Avatar
i used the clamps that came with them but they leaked like a sifter so i got some 3" wide ones and now all is good.
Old Mar 3, 2006 | 04:48 PM
KilerTA's Avatar
could you send some links to what your talking about so i know what to get thanks
