TD newb question
Old Mar 3, 2006 | 08:42 AM
leftme4dead's Avatar
Default TD newb question
The tsp true duals that everyoneh as is the rumbler system right? Im just wanting to make sure because I never see td's or rumbler mentioned together, always sperate. I look on the website and the only thing is the rumbler.
Old Mar 3, 2006 | 08:55 AM
300bhp/ton's Avatar
As far as I know the Rumbler is a Y pipe setup using a Dynomax bullet, very similar in idea to an SLP LM 2 system only not in stainless steel.
The Dual X-pipe setup, may also be referred to as a Rumbler but I don't know. Just make sure that what you are looking at is either a Y setup or a dual setup as it can only be one or the other.
Old Mar 3, 2006 | 09:14 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are unsure about anything or have a question. The most effective way to get a good solid answer is to give them a call. I would say call TSP and see what they are going to recommend for your setup. I believe that the Rumbler however is the TD setup.
I am running the Lanes TD setup. There are many different types of TD's out there. Either way they are all pretty loud.
Old Mar 3, 2006 | 09:30 AM
2K2WS6TA's Avatar
TSP calls their true dual system the Rumbler X, they also have a catback called the Rumbler (kind of confusing IMO) both systems are in the catback section, on the 2nd page, the TDs are also shown in the TD section
