Header bolt size please.
Old Mar 4, 2006 | 07:37 PM
ShevrolayZ28's Avatar
Default Header bolt size please.
I see ARP sells 3/8" X 0.75" and 3/8" X 1.0" header bolts. I know I need sixteen of them but which length? 1.0" or 0.75"?
These are for an 02 Z28 with GM gaskets and Kooks headers.
Thanks!
Old Mar 4, 2006 | 11:24 PM
akZ28's Avatar
I belive they are 8mm by 25mm and you only need 12
Old Mar 5, 2006 | 10:37 AM
Ok, looking at my header sitting in the living room, I see six per side.... = 12 total lol.
25mm is real close to 1". I know people re-use the stock bolts all the time, but I also read of people snapping them off and stripping them. I'd really like to end up with the exact same length of threads in the head.
I might just remove one from the car a take some measurements.
Old Mar 5, 2006 | 01:06 PM
akZ28's Avatar
reusing the stock bolts is not a good idea because you would have to put washers to make up the difference in the thickness between the stock exhaust manifolds and the new headers, The 3/8 thick will not work because i tried them.
Old Mar 5, 2006 | 06:24 PM
OK, so the stock bolts are 25mm in length and they are too long to use with Kooks headers?
Old Mar 5, 2006 | 06:30 PM
BackinBlack02SS's Avatar
You can reuse the stock bolts. The flange thickness of the kooks headers should be nearly identical to the stock manifolds.
Old Mar 5, 2006 | 07:10 PM
Thanks for your help. I know I've seen lots of people reuse the stock ones but I want new ones.
I noticed that the LSx Stage8 locking bolts are listed as being 8mm-1.25 x 22mm FWIW.
Old Mar 5, 2006 | 07:44 PM
lol they use the same size on the 5.0 Ford.
 Michael S. Palmer
Old Mar 6, 2006 | 08:21 PM
akZ28's Avatar
my bad didnt read that you were using kooks, i have pacesetters with the smaller flange
