Wires for coil relocation
Old May 20, 2002 | 03:53 PM
ProModTA's Avatar
Default Wires for coil relocation
For those that have relocated their coil packs. What wires did you use for the mod? Im undesided.
Doug
Old May 20, 2002 | 08:26 PM
GeorgeC's Avatar
Default Re: Wires for coil relocation
MSD 8.5mm wires here. They were a cut-to-fit kit for an LT1 car (90deg. boots), and I bought straight boots separately.
The boots are a really tight fit over the wires. I've made up a few sets of Taylor wires in the past, and found them much easier than the MSD's.
Old May 21, 2002 | 03:29 PM
ProModTA's Avatar
Thanks for the info.
Doug
Old May 21, 2002 | 08:53 PM
Postal's Avatar
I went with the cut to fit Taylor race 409 wires. I've personally always had good luck with Taylor wires.
Old May 21, 2002 | 11:35 PM
SlowZ28's Avatar
When making new plug wires. Is it about the same as crimping a coax cable, or is there more to it than that?
Old May 22, 2002 | 08:50 PM
GeorgeC's Avatar
I'd say it's a bit easier than messing with coax cable as far as the splicing/stripping goes.
The hard part is working with the boots. They are usually a really tight fit. A little GOJO handcleaner makes a nice lubricant that won't harm anything and wipes right off when you're done.
