need help with cat placement on hooker ory
Old Mar 7, 2006 | 07:09 PM
arfrsairbrush's Avatar
Default need help with cat placement on hooker ory
i have a set of hooker lt's with a hooker ory. the smoggy smell is killing me so i bought a pair of magnaflow cats. ive heard issues of a tight or impossable fit without floor pan noise or ground clearence issues, so i need info on the cat placement on each side of the y......has anyone done this before...let me know ....thanks
Old Mar 7, 2006 | 08:44 PM
ttttt
Old Mar 7, 2006 | 11:15 PM
CW00BlackTA's Avatar
When I did my headers I looked at the same thing but with the stock cats (which are nice and small and can be made to 3 inch diameter). Even with those you are faced with an exhaust system that is pretty low. Probably get by with it if you are not lowered. I finally gave up and went without. I've never had any bad smells with mine after the first few days. Get it tuned and give it some time.
Old Mar 8, 2006 | 12:00 AM
TheBlurLS1's Avatar
That's what she said...
You can cut the little slip-fit parts off of the end of the cats which makes them shorter, then you can just sorta butt-weld the pipe to the cats to fit them into tigher spaces.
The exhaust shop that put my cats in had to do this. Check out the link in my sig if you want to see some pics of it.
The driverside cat had to be tilted a bit to fit into the spot, but it works. Passenger side should be no problem, driverside is always the bastard.
Old Mar 8, 2006 | 12:07 AM
Benjamin Russick's Avatar
I tried to weld in SLP cats and they looked like a nightmare. Are the Magnaflows smaller? Random Techs? This is a great question BTW...
Old Mar 8, 2006 | 03:09 AM
shawn's SS's Avatar
Good luck, there's no damn room on the drivers side!
Old Mar 8, 2006 | 05:21 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You might be better off selling it for a catted Y. Sounds like it is going to be a headache.
