Need Help: ASR, ABS & Brake light on
Old May 22, 2002 | 06:10 AM
SSoramac's Avatar
Default Need Help: ASR, ABS & Brake light on
We just got done doing some work to the car (Engine, Rearend and underneath) and now the ASR, ABS, and brake lights are all on. I cant seem to find what i missed (loose plug?) Any ideas?
thanks
mike
Old May 22, 2002 | 04:03 PM
SSoramac's Avatar
Default Re: Need Help: ASR, ABS & Brake light on
Anyone?
Old May 22, 2002 | 04:11 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I would check the wires running into the top of the rearend, as well as all four ABS sensors. What rearend work did you do?
__________________
Old May 22, 2002 | 05:24 PM
SSoramac's Avatar
Trevor,
Thanks, I changed the diff cover from a ta back to stock, the only thing different though is we used rtv and not a gasket, we didnt even touch inside the rearend though. Ive already checked those wired 3 times, but i never found a break or a pinch in them. i didnt find any connections near it, is there supposed to be anything plugged directly into the rearend?
thanks again
mike
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Trevor D:
<strong>I would check the wires running into the top of the rearend, as well as all four ABS sensors. What rearend work did you do?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old May 25, 2002 | 12:17 AM
andy98Z's Avatar
Are you running new tires or slicks?
