27 degrees of timing at WOT
Old May 31, 2002 | 01:27 PM
Fulton 1's Avatar
Default Re: 27 degrees of timing at WOT
It's normal to see timing in the 40* range at part throttle. Prior to MAFT and HPP3, my 2000 SS would consistently sit around 40* cruising in 6th gear. WOT is really what you should be concerned with and 27* is about the max (actually it would always max out at 27.5*) that I was getting on the stock tuning.
Hope that helps.
Old May 31, 2002 | 09:21 PM
Dope's Avatar
Yup, sounds right. I see 27.5 max timing at WOT with the stock MAF. About 30 with ported ends.
It is plenty normal to see crazy timing figures at part throttle.
Dope
Old May 31, 2002 | 10:01 PM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dope:
<strong>Yup, sounds right. I see 27.5 max timing at WOT with the stock MAF. About 30 with ported ends.
Dope</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup. I get 28.5-29.5 at WOT and 40 at PT. The PT advance is to keep the plugs clean.
SC
<small>[ May 31, 2002, 10:01 PM: Message edited by: SS00Blue ]</small>
Old Jun 1, 2002 | 12:29 AM
2000 Camaro SS's Avatar
Default 27 degrees of timing at WOT
What would make my timing be 27 at WOT then go to 40 at part throttle? Would a bed 02 sensor cause this?
Old Jun 1, 2002 | 01:54 PM
WILWAXU's Avatar
moving to the tuning section..]
https://ls1tech.com/ubb/cgi-bin/ulti...;f=23;t=001204
<small>[ June 01, 2002, 01:55 PM: Message edited by: WILWAXU ]</small>
