TSP ORY and pacesetters???
Old Mar 11, 2006 | 03:09 PM
ashade98's Avatar
Default TSP ORY and pacesetters???
I want to make sure I'm putting this thing on right!
IS THIS RIGHT?
I can't get the pass. side all the way to the front of the collector flange. I can deff. make it work, also realized that the tunnel brace won't even come close to fitting!!
Got me to thinking.... IS THIS RIGHT???
Old Mar 11, 2006 | 03:13 PM
Lithium's Avatar
SSU's Drunk Typing Whore
yeah thats right. Good luck with the install...I had to wrestle around with mine for a while to get it perfect.
Old Mar 11, 2006 | 03:14 PM
ashade98's Avatar
Did you get the tunnel brace back on?
Old Mar 11, 2006 | 03:16 PM
Lithium's Avatar
I removed that **** a long time ago...I sure as hell dont miss it.
Old Mar 11, 2006 | 10:02 PM
carado1984's Avatar
spohns tunnel brace with driveshaft loop works well for the big y.. also lets you mount the a tq arm to it...
Old Mar 11, 2006 | 10:46 PM
ashade98's Avatar
Good input... Thanks, I'll check it out!
Old Mar 12, 2006 | 01:46 PM
ashade98's Avatar
Default TSP ORY braces/hangers???
Anybody weld (have welded) on any braces on the Y, or tabs for the factory mount(s)? Just thinking about how little there is actually holding your exaust to the heads. A handfull of 10mm (?) bolts and a couple rubber hangers out back..... Any input??
