160 thermostat mod
Old Jun 2, 2002 | 11:12 AM
QuickSilverTA's Avatar
Default 160 thermostat mod
Im doing the thermostat mod as shown here http://www.ls1info.com/article.php?sid=180. I just had a question of what size of shim to use. I've got a 2000 car i know they come factory with a 180 thermostat, or so i've read. I know on the 194 thermostat you shim it .101 and it makes it open at 180. Thats a 14 degress change. So if I just shim my 180 thermostat .101 i would be at 166 thermo right? or wrong?
Old Jun 2, 2002 | 06:12 PM
AlonzoVersion 1.0's Avatar
Default Re: 160 thermostat mod
Just but the 160 degree bro and then if you want you can shim that.
Old Jun 2, 2002 | 08:06 PM
Old Jun 3, 2002 | 04:58 AM
Patman's Avatar
I did that mod to my 98's stat and used a 3/16" shim to give me approximately a 160 stat.
Old Jun 3, 2002 | 07:52 AM
MYBLKSS's Avatar
Where can you get the shims at?
Old Jun 3, 2002 | 08:12 AM
Patman's Avatar
What I did was take the end of a small screw (one that didn't have a point on it) and cut it off with a dremel tool. You want to find one that is approximately the same size as the hole you are putting it in, so it doesn't flop around or anything.
Old Jun 3, 2002 | 09:22 PM
TTT
