A More Quiet GMMG
John
John
JFYI I race the car in the Cannonball One Lap Of America, we covered 7500+ miles in 9 days. I know what I can get away with during the wk for exhaust noise and the dyno max isnt going to cut it.
John
John
Thanks man! No dynomax for me! Guess I'll try the magnaflow..........
I think I'll give the magnaflow a shot, and if that doesn't work I'll consider swapping to another catback.
They are only like 50-70 bucks too. A true 3" inner diameter flow path(no sacrificing flow) and it will help tremendously! Get a 20" muffler and have it welded into the i-pipe. That would tone down the loudness but you'll retain that badass sound.
Just a 3" I/O round muffler in the I. I'll have to give the $$ some thought.
I've gone back and forth between the powerstick and magnaflow. I figured the magnaflow would have more sound reduction with it's stainless steel packing. I could almost go either way. Too bad no one else has done this to their GMMG!
- Dyno max doesn't quiet it much
- Borla 5" round just fits and quiets it quite a bit but changes the sound
- Stainless works will make you a chambered section for the I pipe that runs from Y to the bend that goes up over the axle for about the same price as the Borla (I think it's about 24" long). Quiets it down, and keeps the chambered sound.
- GMMG will sell you a replacement I pipe for $100 if you're worried about restoring it to original.
- Stainless works will make you a chambered section for the I pipe that runs from Y to the bend that goes up over the axle for about the same price as the Borla (I think it's about 24" long). Quiets it down, and keeps the chambered sound. - GMMG will sell you a replacement I pipe for $100 if you're worried about restoring it to original.
Come again? Original parts? I'm doing a different heads cam setup than I already have, and longtubes with my GMMG. I don't have any "quiet parts" lol.
Yeah, I didn't want the Borla because I'd lose too much clearance with it being 5". I've thought about a stainless works or power stick, but didn't think it'd quiet it down enough. That's basically what the SW chambered catback is right? They are similar to the GMMG only with a chambered muffler in the I pipe I believe, and are pretty loud?? Do you have a SW's in your I pipe right now? If so, how much did it quiet it? Does it still sound the same, only more quiet?
