solid mounts and your frame
Old Mar 13, 2006 | 12:41 PM
RICEBURNER's Avatar
Default solid mounts and your frame
so i am going to be getting the sphon solid motor mounts, i have the poly trans mount already to go in this weekend...but my ? is that i heard that with those mounts on the stock frame that you can actually bend the frame?!? is that true? i was told that i need to get a set of SFC's first to stiffen the frame....while i am not opposed to that ...i dont want to wait that long....please let me know if i would twist the frame if i just went ahead with the mount install! thnx in advance!
Old Mar 13, 2006 | 02:47 PM
00SLPSS's Avatar
even before solid motor mounts subframes are always a good idea, unless you just granny your car, if possible get SFC as soon as you can.
Old Mar 13, 2006 | 03:07 PM
JustAnIlluzion's Avatar
Old Apr 6, 2006 | 11:23 PM
RICEBURNER's Avatar
anyone else have any input?
Old Apr 8, 2006 | 01:27 PM
gearheads78's Avatar
I would run the SFC no matter what you do. But you may want to rethink the solid mounts unless this is a track only car. With solids you will feel "EVERY" every vibration in the car. A better choice is the urethane mounts. You still feel some but its not near as bad as solids.
good luck
Old Apr 19, 2006 | 01:29 PM
"Grabby" 2000Z28's Avatar
Cool
I love the feeling of every little twitch of that LS-1 !
The tweak of the frame when you rev it at a stoplight .
If you're like me , go with the solid mounts . It does take a few pounds off the front end too .
