In the middle of MAC install, need help....
Old Jun 9, 2002 | 04:37 PM
MONGOOS's Avatar
Default In the middle of MAC install, need help....
Ok, from 10:30 to 3:30 today I've been working on getting MAC's in with a friend. So far, we have the drivers side manifold off, plugs out, y-pipe taken off, and O2 sims installed. We can't get the header to snake up on the drives side, and I'm completely lost where to even start on the passenger side. There's not even enough oom to fit my socket back there for some of the manifold bolts. Anyone have some tips on how to make this whole mess more painless? I'm driving myself nuts trying to snake that drivers side header in there. I was told to unbolt the engine mount and jack it up an inch or two... but i'd like to avoid that if possible.
<small>[ June 09, 2002, 04:52 PM: Message edited by: MONGOOS ]</small>
Old Jun 9, 2002 | 05:02 PM
GS WS6's Avatar
Default Re: In the middle of MAC install, need help....
The easiest way to get the driver side header in is from the bottom.......If you will remove the 4 15mm crossmember bolts and allow the rear of the tranny to hang down it will give you more room to work with. You may even need a friend under there with you with a prybar to help move the tranny an inch or two more towards the passenger side. It will go in I promise <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The passenger side is not as bad as it looks, just remove everything that is in you way, the coil packs, dipstick, airpump tube, ect.....The header will also go in from the bottom and will be easier to get in place than the driver side.
Good luck.
Old Jun 9, 2002 | 05:40 PM
zZAndrusZz's Avatar
Another way you can do a MAC install (the way I did it) I removed the motor mount bolts one at a time, and jacked the motor up just a couple inches. This allowed me to slide them right up in there, this method works for almost all types of headers too. Just be sure both motor mounts are loose before you start jackin the motor up. I found this way much easier than removing the coil packs. Just my .02 though. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Andy
Old Jun 9, 2002 | 10:13 PM
jmX's Avatar
jmX
Stock manifolds come out through the bottom.
macs go in from the top, valve covers removed.
Old Jun 9, 2002 | 11:06 PM
rnr27band1's Avatar
i got my passager side in from the top after taking off the coil packs and valve cover, i got the drivers side in from the bottom, all i can say is just stay with it and it will go in, i have heard of people removing the oil filter to get the driver side in. if you got any more ?'s just email me.
Old Jun 10, 2002 | 10:43 AM
Lane's Avatar
Top, top, top. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jun 10, 2002 | 07:09 PM
StevieZ's Avatar
Coil packs and valve covers off. From the top! So how did you make out?
<small>[ June 10, 2002, 07:42 PM: Message edited by: StevieZ ]</small>
Old Jun 11, 2002 | 08:26 PM
Riptide's Avatar
I've put MACs in from the top as well as from the bottom. The last install I did, though, was a set of SLP long tubes. After removing the starter and the oil filter, I supported the K-member with the jack, loosened the two front K-member bolts and removed the four rear bolts, and lowered the rear of the K-member without ever touching a motor mount bolt. This gave me all kinds of room to get the SLPs in without so much as a scratch. I would think that MACs would go in even easier this way. Somebody give it a try and let us know how it works out. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
 Michael S. Palmer
Old Jun 12, 2002 | 04:37 PM
CAlley2001's Avatar
I got both mine in from the bottom. Just had to remove the first 3 coil packs on each side and thats it. For the driver side I jacked up the engine just like 2 inches, didn't remove any mounts or anyting. Passenger side it just went right in.
