SVO 30# injectors
Old Jun 10, 2002 | 08:02 AM
2000 Camaro SS's Avatar
Default SVO 30# injectors
If you install new 30# injectors (Ford) will you have to re-program the computer for all of the new fuel? Will the computer learn on it own?
Old Jun 10, 2002 | 11:22 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: SVO 30# injectors
I'm going to put a copy of this in the tuning section as well.
__________________
Old Jun 10, 2002 | 01:33 PM
With out re-programin would the car have small low RPM backfires? I just put in the injectors and have to go get the car reprogramed this Friday but right now it runs RICH. Would this be the problem?
Old Jun 10, 2002 | 04:05 PM
Ragtop 99's Avatar
Not for a day or two. L-T it can cause some problems for your O2 sensors and cats. You should only be rich (blowing gas out the tailpipe) at cold idle and WOT unless you are really far out of whack.
Old Jun 11, 2002 | 12:58 AM
Ragtop 99's Avatar
Reprogram unless you were incredibly lean before the injector swap.
