How to crank engine without starting?
Old Jun 10, 2002 | 11:11 AM
Jake99SS's Avatar
Default How to crank engine without starting?
I've noticed that after I change the oil, it takes a couple seconds longer than normal for oil pressure to come up. Is there a way to crank the engine over continuously without it firing to build pressure? Maybe pull the fuse for the injectors?
Old Jun 10, 2002 | 01:11 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: How to crank engine without starting?
You can pull the fuel pump fuse and the motor will turn over but not start. That's how we pumped up the lifters after doing heads/cam.
Old Jun 10, 2002 | 01:13 PM
Fulton 1's Avatar
One thing you can do (if you don't already) is to fill the oil filter with oil before you install it during an oil change. This will help minimize the time it takes to build pressure (its pretty much like starting a cold engine at this point).
Old Jun 10, 2002 | 01:38 PM
JR HAWK 9's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>You can pull the fuel pump fuse and the motor will turn over but not start.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I do this every year after taking it out of storage for the winter, just to prime the oil pump and to get the oil moving a little bit again.
