Throttle spacer
Old Mar 14, 2006 | 10:15 AM
BOTTLE ROCKET's Avatar
Default Throttle spacer
Has anyone seen any hp increase using a throttle spacer? One of the vendors sell a N2O injection plate that showed an substanial increase in NA power when dyno'd. If that's the case, I might consider running one even if I don't install the N2O plate.
Old Mar 14, 2006 | 10:50 AM
TARZAN's Avatar
I'd only advise gettin one if it was that nitrous plate, thats the only way you'll see any REAL gains outta it
-Will
Old Mar 14, 2006 | 10:56 AM
Camaroholic's Avatar
It's only proven effective on wet manifolds (fuel gets sprayed in the intake inlet, a la TBI systems or carbs)... our intakes are dry. If spacing the throttle is effective on our cars, heck, put the throttle body in the fender well and run a pipe up to the intake manifold. Why stop at 1/2" or whatever...
Old Mar 14, 2006 | 11:34 AM
LS69TA's Avatar
Don't forget to install the Tornado as well...
Old Mar 14, 2006 | 11:48 AM
I agree with it being effective on wet flow (ex TBI) manifolds. I've seen some dyno #s on some TBI spacer test where they picked up significant hp and torque. I hadn't really seen anything on dry manifold setups and I guess that's why. I was checking into replacing my N2O injector with one of the new plate injectors, and a couple of the guys mentioned that during a head to head test, the engine even picked up several hp when they weren't spraying........Just wondering why
