Last plug on passenger side *%$#*???????
Old Jun 12, 2002 | 12:20 AM
numbZ's Avatar
Default Last plug on passenger side *%$#*???????
What is the trick to get to the last plug on the passenger side? I can`t even get my hand on the boot.I know a lot of you change plugs frequently.Any and all advice would be greatly appreciated. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 12, 2002 | 12:21 AM
WayneSS01's Avatar
Default Re: Last plug on passenger side *%$#*???????
From under the car.
Old Jun 12, 2002 | 12:36 AM
numbZ's Avatar
Thanks for the tip Wayne. I thought about doing that sunday when it started raining like a biotch.I guess I`ll climb under there and mangle my arms and hands some more.
Old Jun 12, 2002 | 12:40 AM
WayneSS01's Avatar
You bet. What's funny is after you're under the car this is the easiest plug to get out.
Old Jun 12, 2002 | 12:54 AM
Craig98WS6's Avatar
You won't get to that plug if you have a 98 or 99 from under the car. You need to remove the air tube and coil packs for the last 2 on that side and then a short extension. Also put tape on the sharp plastic tips under the cowl to avoid some of the cuts.
