will different length O2 sensor wires cause problems?
Old Jun 15, 2002 | 10:25 AM
gator's 99TA's Avatar
Default will different length O2 sensor wires cause problems?
i have been battling an SES light that brings up "insufficient switching" bank 2 code. i have extended (spliced) the O2 sensor wires for my LT headers. is this causing the problem? i have switched out an old set for a newer set of wires but i extended them the same way. what could it be? thanks!
Old Jun 15, 2002 | 04:33 PM
Dipstick's Avatar
Default Re: will different length O2 sensor wires cause problems?
If you didn't solder them, you could be getting incorect reading to the PCM. The voltage range is .1-1.0V
