LOUDMOUTH QUESTION???
Old Jun 17, 2002 | 05:47 PM
Trans Am WS6 RGS's Avatar
Default Re: LOUDMOUTH QUESTION???
A lot of time it will sound raspy when its still cold but even after its warmed up there will still be some raspiness. As for the rattling noise, mine had a slight rattle also but it was cause by the cat back not being installed perfect. I took it back and they fixed it. Turns out that the part that goes over the axle was touching the control arm and that was causing it to rattle.
Old Jun 18, 2002 | 12:46 AM
RICHS_Z28's Avatar
Default LOUDMOUTH QUESTION???
i just had my loudmouth exhaust put on and it sounds really good,but my question is when its in neutral and rev it.it sounds good but when the rpm's are dropping it has this ugly rattle noise from where the exhaust starts around the resonator area. can this be fixed easily or should i take it back. really appreciate the help.
