Will MAF ends effect tranny line pressure???
Dope
<strong>I know that porting yur stock ends reduced line pressure...but do, say...thunder racing ends reduce it also???</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, any of the aftermarket MAF ends will cause the same problem because it's the same thing as ported stock ends. You're moving the air in a larger diameter hole, and less air is passing over the MAF sensors. The PCM reads less air, so it decreases line pressure since the MAF is one of the parameters measured to determine line pressure. I wouldn't try a set of ported ends unless you've had your line pressure set to vary directly with your TPS via custom tuning. Even then, you're not seeing added power from added airflow. It's the increased timing and leaner a/f ratio that show the increase in power.
