Just Got SES checked out
I'd do it quickly as possible, if you're running lean enough to set a code it does not take long for severe engine damage due to leaning out. The detonation is going to take its toll.
Dope
<strong>It said in the article to port the MAF as well as the ends. As long as you don't hit the sensors they said it should be fine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You should only be porting the MAF ends and leaving the electronics (black plastic piece) alone! It sounds like you maxed out your LTrims. The PCM has a max adjustment of 25% either way for a rich or lean condition. If the LTrims are positive, that means that the car is having to ADD fuel (i.e. it's lean). If the LTrims reach 25%, then the PCM can no longer adjust for the lean condition. That's when it pops the SES light on. Just get another set of stock ends, and you'll be fine. Post up in the classifieds section that you are looking for a set of stock, unported MAF ends. I bet somebody has a set for sale.
The car's not going to "blow up", but it will probably not run right as is. You should be able to get a new MAF from gmpartsdirect.com or one of the GM parts sponsors for a reasonable price.
If you have access to an AutoTap you can confirm your situation. This is really an invaluable tool that you should have before doing mods like this.
As a temporary band aid you can likely get away with a set of stock, unported ends or a MAFT (to richen the base setting) which you can probably pick up cheap in the classifieds until you can get a new MAF. Either of these might be enough to put the MAF signal back into a range for which the PCM can compensate. This is only a temporary solution though since you may still be getting too much timing. Again, just shooting from the hip without AutoTap.
<small>[ June 21, 2002, 11:16 AM: Message edited by: Fulton 1 ]</small>
The reason aftermarket MAF's get away with not having those pieces is you're dealing with a completely different set of electronics that were calibrated for that kind of airflow without restriction. Your stock sensor is calibrated with a stock flow in mind. Porting it out to a certain extent is a good thing, too much is a bad thing.
I'm sure you can find a set of stock MAF ends or even a complete MAF in the classifieds section of this site. If you want, try putting the screen back in until you can get ahold of some new parts. It might help a little...
Dope
I put a Want to buy add in the Classified and asked if anyone wanted to sell a Stock Maf shipped to me for 50 bucks. I had 5 emails in 1 day.
Just an FYI.
Again, IMO you should buy yourself a complete stock MAF (i.e. black plastic piece/electronics and the ends w/screen) and use that instead. I would not screw with the MAF at all unless you have access to AutoTap to see what your changes are.
