oxygen sensor simmulators
Old Jun 23, 2002 | 12:43 AM
fullsizechevy's Avatar
Default oxygen sensor simmulators
Are these a good idea to run? what are the pros and cons? Dont they just tell your computer you are running at a certain mixture. Does it make your computer run at that mixture or just tell it it is? Do they hurt performance?
Old Jun 23, 2002 | 02:57 PM
WILWAXU's Avatar
Default Re: oxygen sensor simmulators
O2 sims are used only on the rear O2 sensors.. they monitor emissions output only.
Old Jun 23, 2002 | 03:30 PM
Supertrapped's Avatar
Speed freak
You only need them if you don't have cats on the car.
Old Jun 24, 2002 | 08:44 PM
I am removing both my cats and want to put the cutouts in place of the cats. I was going to put the o2 simm at the last o2 sensor. Should I install an a/f ratio gauge and see what its running at stock then after I do the cutouts and o2 simm see what its running at. This way I can tell if my engine is running ok right? Anyone with problems that have done this similar setup?
