Problem with my idle... any ideas?
Old Jun 24, 2002 | 06:16 PM
Jim Mills's Avatar
Default Problem with my idle... any ideas?
Ok here is what happens. I'm at the track and I'm in the waterbox I do my burnout and roll forward. I pull the car out of gear(using the clutch) and the RPM's seem to stay at like 2200-2500 for about 5 seconds then fall down to 850ish (regular idle). Has this happened to anyone else? Is this normal? If not normal and it's not an easy fix how do I go about describing my problem to the dealer as the above might not cut it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> LOL
Thanks Guys... Car is a 2001 Firehawk M6 with about 6,000 miles.
Old Jun 24, 2002 | 10:27 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Problem with my idle... any ideas?
Mine does the same thing.I have over 40 passes this year with this problem.What I do is,do the burnout and roll out.push the clutch and the rpms stay at 2000.When this happens I let the clutch out a little to pull the rpms back down.
Old Jun 25, 2002 | 06:09 AM
Jim Mills's Avatar
so we both have the same problem.... I only find it annoying because I can't go and directly stage the car.... Anyone else with some ideas? someting with the IAT?? what about the TB?
Old Jun 25, 2002 | 06:50 AM
dfarmercse's Avatar
From what I have heard that this is normal. The PCM holds the idle high for a few seconds and then lets it return to normal. Not sure the reason why though.
Old Jun 25, 2002 | 10:26 PM
Bub's Avatar
Bub
Think is has got to do with keeping emisssions down.
