1st try......failed
Just run any wire from the coil to the plug directly below it. The important thing is that you keep each coil pack in its correct location.
edit: I also don't wanna try to hammer it off or anything since that manifold is hanging by one bolt left.
update: I finally got the driver side manifold and cat off!
Make sure you have the car at least 2 feet up in the air, it will make getting the headers in alot easier. It's always easier with a lift, but can be done with the car on the ground. The hard part is getting the drivers side in, that one usually has to have the collector pointed at about 5 oclock to get up where it has to go.
also, take the oil filter off, you dont have to drain all the oil, but just let what runs out, run out, and add around 1/4 of a quart of oil when all is said and done... it should help you get that driver's side header up...
but t least there in.....bad news that i think i cross-threaded one thread on the drivers side(the middle one) but all the other ones are tighter then a virgin. either the old or new bolts wanted to go in all the way(thank god I'll be changing heads next summer
other then that everythings good. i'll put on the Y-pipe and put everything else back together either tomarrow or wednesday....thanx uys for being there when i needed help...and OMG I'm SORE!!!!pCe....paul
