Sanity check on header install list?
Old Mar 20, 2006 | 02:56 PM
X-JeSSter's Avatar
Default Sanity check on header install list?
Hi folks,
About to order the stuff for a long tube install, and have the following prepared. Anything I'm missing?
1. Order GMMG exhaust (check! on the way )
2. Order Pacesetter race-style headers
3. Order TSP Catted Y Pipe
4. Grab Bosch 13111 vette rear O2's for my front O2's (or should I use Delco?)
5. Buy O2 simms for the rear O2's
6. Re-use stock header bolts
7. Re-use stock header gasket
8. Uninstall the rest of the AIR system.
This should cover me, right?
Thanks!
Bryan
Old Mar 20, 2006 | 03:27 PM
X-JeSSter's Avatar
Add a change to that: Should I bother with O2 simms since I'm going to throw a code for no AIR anyway? Then, whenever I get those AIR codes tuned out, I could go ahead and get the rear O2's deleted from the program?
Thanks...
Old Mar 20, 2006 | 03:29 PM
01TAFlyer's Avatar
Yes, I wouldn't get rear O2 sims. Just get them tuned out along with the AIR codes. Much easier and cheaper.
Also, I would buy new gaskets and ARP header bolts. You could get away with not, but it isn't that much money and cheap insurance imo.
Old Mar 20, 2006 | 03:35 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I use locktite on my header bolts.
Old Mar 20, 2006 | 03:36 PM
X-JeSSter's Avatar
Cool, I'll throw ARP header bolts on the list. Do these things need to go in with any locktite? I hadn't planned on using a torque wrench, but should I?
Also, I'm still not sure of the answer to this question - pretty much ANY check engine light throws the computer into open loop, right? Does this really effect performance on LS1's? In other words, are these codes something I should tune out before some shakedowns at the track?
Thanks,
Bryan
Old Mar 20, 2006 | 03:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Or solid mounts....
Old Mar 20, 2006 | 03:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What the hell is going on with my posts? It looks like I am psyhcic for both of you!
Luna's Avatar
I would add polyurethane motor mounts to your list unless you want to listen to your Y-pipe jack hammering your floorboard
Old Mar 20, 2006 | 03:57 PM
2K2WS6TA's Avatar
Add a set of plugs (just in case you crack one intalling or removing) NGK TR55s $1.68 each
Old Mar 20, 2006 | 04:02 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Plus that is optimal time to change them!
Old Mar 20, 2006 | 04:05 PM
X-JeSSter's Avatar
Anything wrong with using OEM plugs? AC Delco Platinums I think? Or are the NGK's just fine?
Old Mar 20, 2006 | 04:52 PM
2K2WS6TA's Avatar
Either one will work, just have some on hand, as it's easy to crack the ceramic insulator, and then the plug doesn't work and the car won't run right
Old Mar 21, 2006 | 03:15 PM
daryl2cb@yahoo.com's Avatar
get the arp studs, so you can hang the header on them from below, great if your doing it by yourself, I used antiseize on these, but I am getting heads soon so I wanted to reuse my 80 dollar studs.
Old Mar 21, 2006 | 04:41 PM
01TAFlyer's Avatar
I used anti-seize as well, not loctite.
