Red sticky fluid leak, UGHHHH!
Old Mar 20, 2006 | 02:58 PM
kanewolf's Avatar
Default Red sticky fluid leak, UGHHHH!
I'm getting a red sticky leak coming from somewhere near the underside of the power steering res. But I don't think it's power steering fluid, its too red. It is running down the engine, then under and accumulating near the oil pan. I can't tell what type of fluid because I'm not sure if the red color is from the heat or if it's naturally red. Any suggestions would be much appreciated.
P.S. no, it's not blood
Old Mar 20, 2006 | 03:02 PM
NoGamesLS1's Avatar
Tranny fluid is usually red. Do you have any sort of trans cooler that runs up around there?
99ssleeper's Avatar
auto or manual?
clean everything off well, the check it again later and see if it comes back or where it's coming from.
Old Mar 20, 2006 | 04:10 PM
Mr Incredible's Avatar
Check your PS fluid level and while you're at it see what color it really is. That's the quick and easy first check that I'd do. If nothing else you'll know what it maybe isn't.
Old Mar 23, 2006 | 10:10 AM
kanewolf's Avatar
It's an A4, I did check the PS fluid, and it doesn't look red at all. So while the leak seems to be coming from underneath the resevoir, I'm not convinced its the PS fluid. The level was a bit low, which could mean that when it gets hot, it turns red. Maybe I should take a little dab of my PS fluid and hit it w/ my torch to see if it goes red. Anymore suggestions would be greatly appreciated.
Old Mar 23, 2006 | 10:25 AM
Xtnct00WS6's Avatar
Sounds like u have a leak in your tranny. Our transmission fluid is red.
Old Mar 23, 2006 | 11:30 AM
John_D.'s Avatar
The red is not from heat.
Power steering fluid will be red (unless it's old/burned and then it's brown). It will be oily more than sticky.
Dexcool will be red too. If it's a very slow leak, it will be sticky.
Old Mar 23, 2006 | 04:23 PM
kanewolf's Avatar
Hmmm. When it puddled on my garage floor, it was almost like a candle that drips wax then semi-hardens. So, I couldn't really say if it was oily or sticky. I don't think its tranny fluid, cause it has no reason to be coming from under the PS reservior area. Maybe Dexcool, but again, the current fluid in the PS res. is old and brown, so if that is the culprit, then how could it turn red once it leaks out???
I appreciate everyone's help, I'll get this thing figured out sooner or later.
Thanks
Old Mar 23, 2006 | 04:35 PM
s346k's Avatar
check your antifreeze.
my buddy had a "red sticky gel-like substance" on the bottom of his hoses, etc...we determined that his waterpump was leaking onto the pullies/belt...then it just got splashed onto everything else from there.
Old Mar 23, 2006 | 06:22 PM
boondiggys's Avatar
atf is the same as power steering fluid...i put the tranny fluid in the steering no problems...id check the line on the bottome of the resevoir, the clamp can come loose...
