I got my catch can in :)
If you search online it under Aircompressor and accessories page 4
Why would they design the motor to have oil go in the intake?? even it its not designed that way,how does oil get in the intake?? I mean if the intake gets air from the lid,where the hell does the oil come in??
I never did/had a performance car,so I'm not to experienced in doin the work so...
And could someone post a pic of where exactly the hose goes in and out of the intake....is there a tube going in the back of the intake or something...Why would the intake have tubes or holes in it anyway....I thought it was just there to direct the air flow in?
It leaves the motor from the valvecovers and travels through a hose, past a PCV valve, and into the intake manifold right behind the throttle body on the passenger side.
The "husky" is an "air/water" seperator normally used for air compressors to seperate the water out of the air before it gets to your air tools. The water can cause their guts to rust and stuff like that. In this application, it's simply seperating the atomized oil from the air/oil mix that's passing through.
As for use on a stock motor, its a perfect investment. The "blow by" increases as your motor gains miles.
hey thats my drawing!
