LS6 Intake Swap
Old Mar 20, 2006 | 09:24 PM
I <3 80057's Avatar
Default LS6 Intake Swap
What do I need besides the intake? Gaskets? What do I do with the EGR fitting? Thanks!
Blake
Old Mar 20, 2006 | 09:33 PM
99camarosupersport's Avatar
you need the gaskets and unless you ordered yours from summit or somewhere or got it off of a newer camaro or firebird then it doesn't come with the EGR fittings, your going to have to remove the egr as most ls6 intakes do not have it..compare the one you have now at the front where it meets the TB and you can see where your EGR goes in it's the thick black rope looking tube, compare and see if yours does or doesn't have the plug for it. and you need the 2 coolant bypass lines. i'm not good at explaining things, check out www.ls1howto.com, they have the ls6 intake swap on there, and it will tell you how if your not sure.
Old Mar 20, 2006 | 09:37 PM
sorry just saw that you already have no egr, but if the ls6 intake does have the egr fitting for some reason then just do whatever you did to plug your ls1 intake when you removed it that's the best i can do for that one lol.
