ASP vs. SLP
Old Mar 20, 2006 | 09:39 PM
corndog's Avatar
Question ASP vs. SLP
Whats the difference between ASP & SLP underdrive pulleys? I was told the SLP crank pulley was about $230. Im looking in the summit mag and they have the ASP crank and alternator pulley for $199.99. Why such a big price difference??
Old Mar 20, 2006 | 09:44 PM
JerseyLS1TA's Avatar
SLP is more expensive then most other companies, but I'm not sure if thats the main reason.
Old Mar 21, 2006 | 07:22 AM
KILLERARMY's Avatar
  • Extra-tall belt-retention "walls"--no more thrown belts!
  • No aftermarket tensioner required
  • 100% steel construction
  • Lighter than the stock balancer
  • Integral timing marks and puller-mounting threads
  • Keyed for high-rpm or supercharged applications
  • Does not cause false knock retard or erratic power-curve dips
  • Includes a new balancer bolt
  • This is what you need to know about SLP Pulley
Old Mar 21, 2006 | 12:05 PM
Redneck Z's Avatar
That's why I bought mine. It's a very nice pulley, and it's made by Powerbond. SLP just calls it theirs. I refuse to buy stuff from SLP on principle alone.
Old Mar 21, 2006 | 01:13 PM
VA2001SS's Avatar
About the only thing that is similar between the ASP and the SLP/PowerBond is the 25% underdrive. The quality/design of the SLP/PowerBond is head and shoulders above the ASP.
Old Mar 21, 2006 | 01:24 PM
BIG_MIKE2005's Avatar
Just go to TSP & get their Powerbond. As stated before same as SLP but cheaper.
Old Mar 21, 2006 | 01:32 PM
ski23's Avatar
have a link to tsp??or point me in right direction?? ty
Old Mar 21, 2006 | 01:48 PM
www.texas-speed.com/shop/ or just call Jon 1-806-866-0734
Tell him Michael from TFCC sent ya.
 Michael S. Palmer
Old Mar 21, 2006 | 02:26 PM
98camaroLS1M6's Avatar
Slp vs. March, which is better?
Old Mar 21, 2006 | 02:42 PM
nokeman's Avatar
I would say all pulleys are relatively the same...performance wise. The only reason why I will be going with the SLP is because of the taller walls. This will prevent throwing belt, which nobodys wants to happen. Its a little more expensive but a small price to pay for the added insurance.
Old Mar 21, 2006 | 03:16 PM
Why pay SLP's marked up price when you can get the Powerbond which is the same pulley from TSP for WAY cheaper. Unless you like wasting money.
Old Mar 21, 2006 | 03:27 PM
8GTOKLR's Avatar
the ASP will work you'll just have to replace your belt tensioner pully with a 3.8 Supercharger Driven pulley. I have the part number for that. the SLP might do well, i dont know cause i havent used it. But either way you dont know till you try
Old Mar 21, 2006 | 03:31 PM
dnm12's Avatar
i see that people seem to like these underdrive pulleys, what are the general pros and cons of them (sorry to hijack)
Old Mar 21, 2006 | 04:47 PM
8GTOKLR's Avatar
Pros= I got 9whp, less rotating mass, rev quicker
Cons: dam belt slipped
Fix= changed Tensioner pully out
Old Mar 21, 2006 | 04:56 PM
SMSFRC99's Avatar
The pros of an underdrive pulley are increased horsepower by eliminating the parastetic drag that the accessories apply to the crank. By minimizing the diameter of the crank (drive pulley) you allow the crank to spin faster/ more free because it will rotate the accessories slower.
the down side is when turning your accessories slower some applications tend to experiance a low charge from the alternator, or on an exessive street build may possibly have a temperature increase.
The alternator can be solved by purchasing a smaller pulley to increase the speed ratio on the alternator, closer to what it may have been stock.
Usually an underdrive pulley on a LS1 will get you a total of 10-12 fly wheel hp when used with the over drive alt pulley I believe you should see 6-8.
Old Mar 21, 2006 | 06:03 PM
98_LS1's Avatar
You can get the SLP pulley from New Era Performance Parts for $206.95 with free shipping. They are a sponsor on this board >>>>>>>>>>
http://www.neweraperformanceparts.com/
Old Mar 21, 2006 | 06:21 PM
FUN LS1's Avatar
I didn't see on TSP's site an alternator overdrive pulley for the Powerbond. Can you use the ASP OD alternator pulley with the Powerbond?
Old Mar 21, 2006 | 06:27 PM
blue01ta's Avatar
You shouldn't need the O/D pulley for the alternator on an M6 car.
Old Mar 21, 2006 | 06:36 PM
Redneck Z's Avatar
You don't need, or want an OD alternator pulley unless you have a big stereo system.
Old Mar 21, 2006 | 09:17 PM
Rescue Ranger's Avatar
I went with the March pulley from byunspeed. I honestly didn't do much research on the topic, I was so filled up with info after picking heads/cam and clutch.
