Help!!!! Need some specifications quick
Old Jul 4, 2002 | 10:55 PM
SSleeper's Avatar
Default Help!!!! Need some specifications quick
I have a 2001 SS. It came from the dealer with the aftermarket slp catback system (Dual Center Mount). I need to know the muffler specifications and/or the exhaust pipe specifications (ID/OD for inlet and outlets). This muffler is welded to my exhaust pipes and the only way to change the muffler is to cut it out. I have a Magnaflow muffler on the way (3" inlet with dual 2-1/2" outlet). I don't mind cutting the old system out as long as I "KNOW" the new one will fit. Once I cut the exhaust will the new muffler fit inside/outside on the exhaust pipes or am I screwed. Sure need help with this!!!! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 4, 2002 | 11:19 PM
Dope's Avatar
Default Re: Help!!!! Need some specifications quick
They are the same size (3"). Take it to an exhaust shop and have it welded on. Will only cost ya like 20-30$ at MOST.
Dope
