How high ocatane can i go???
Old Jul 7, 2002 | 07:02 PM
Satan's Angel's Avatar
Default How high ocatane can i go???
I have heard that a high octane gas will screw with the pcm. So would running turbo blue mak my car run better or worse???
Old Jul 7, 2002 | 08:10 PM
WILWAXU's Avatar
Default Re: How high ocatane can i go???
If your car isn't tuned to use the high octane.. then it's useless waste of cash. Also.. be sure not the run regular (leaded) race gas, that will mess up your O2's.
Old Jul 7, 2002 | 09:15 PM
JimMueller's Avatar
Run the lowest octane which gives you zero knock. If you have LS1_Edit you could create multiple programs to take advantage of different scenarios.
The higher octane fuels supposedly burn slower.
