Finally epoxied the TB
I can't say the way I did it was "scientific", but I can say I have excellent low speed throttle response. Initially I cleaned every surface w/throttle body cleaner, then dressed with a #60 grit dremel drum @ low speed to insure a rough surface in the areas to be epoxied.
For lack of anything better at hand-you're gonna love this- I used Zaino claybar to fill the areas I didn't want epoxy in. I wouldn't really recommend this, as it's very "sticky".
I was in no hurry,though, so cleanup time was no biggie.
I used a plastic soda straw to hold the PCV air inlet open ,and filled around w/clay in the areas I did'nt want to fill w/epoxy.
The IAC inlet (from the plunger side) I filled w/clay to a suitable depth to accomodate the plunger/valve.
I then did about 3 epoxy fills over 2 days-as I said, no rush.
Re-ground the inlet contours with a 120 grit dremel drum, then polished up with a flapper wheel.
I then drilled the IAC cavity and the inlet side w/a drill bit then gradually opened to about 1/4".
I also drilled the PCV inlet to remove all traces of the plastic straw (not necessary-but "felt" cleaner).
IAC counts are good.
Little change in the slightly surging idle I've had since the ST3500 TC install, however.
The only low point was I was walking outside yesterday w/TB in one hand, tools in the other and slipped off my concrete steps and busted me ****, and bent one of the IAC plunger screws (see other post).
Dunno if WOT performance was enhanced, and may never know as I'm not able to avail myself of a Dyno.After a 30 mile drive the cruise LTRIMS returned to their normal 0.0 .
It only cost time and a little epoxy.
Was it worth it? As I said, low speed throttle response is definitely crisper.Beyond that, all I have is the satisfaction of a job well done.
TB Pic 1
TB Pic 2
Final IAC/PCV inlet size was about 1/4". A little larger hole would not hurt.
When first cranked, the IAC may go a little spastic, I suspect because the air volume was reduced so much. You can always go back and drill the IAC from both ends larger if you have idle problems.
Recommend doing this over several days and taking your time.
Note,disclaimer: This worked for me. If it doesn't work for you, well, don't shoot the messenger. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ July 11, 2002, 07:38 AM: Message edited by: gwj ]</small>
