6.0 iron block useres
Old Jul 9, 2002 | 08:53 PM
1dirtyZ's Avatar
Default 6.0 iron block useres
any of you 6.0 iron block useres encountered a cooling issue after the instalation of your new engine ( assuming you used the stock radiator.)???
Old Jul 9, 2002 | 09:18 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: 6.0 iron block useres
I'm getting a 6.0L motor built and decided to just get a .03 overbore to hopefully stay away from cooling problems. Thin cylinder walls can cause problems by allowing the heat to be transferred to the coolant instead of being used and pushed out the exhaust. If there is some other underlying cooling issue with the 6.0L block that would be bad. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Are you running a 6.0 block and having cooling issues? Did you get it bored, what size or are you still running the 4.0" bore?
John
Old Jul 9, 2002 | 09:51 PM
383LQ4SS's Avatar
I was concerned about that as well. But I can tell you I have had 0 cooling problems. Car runs at the same temp as with the aluminum block..evn in 100 degree weather in stop and go traffic.
Old Jul 9, 2002 | 09:57 PM
WILWAXU's Avatar
Great topic for the internal engine section <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Moving to internal engine section.
