Thinking about getting rid of my FTRA
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kenny H:
<strong>I have a tranny cooler and the Fast Toys Ram Air blocking my radiotor. Even with the 160 t-stat the car gets up to 225 degrees according to my ATao, not good. I'm thinking of ripping it off. Should I just take off the lower plate thats blocking the radiator? Does the FTRA 'really' make a difference on a 350+ hp car?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Also, it does no good in hot weather to put in a lower thermostat if the second cooling fan will still not come on until its factory setting of around 215 degrees - do you have your fans set to come on earlier?
Even with a 160 stat and 175 fan settings mine gets up well over 200 degrees in very hot weather (110 degrees) and it does not bother me at all. It used to get very close to this hot in the summer even before the FTRA.
As far as whether the FTRA is a worthwile mod - the answer is yes. Testing I did showed about a .1 second and 1 mph increase in the quarter over the factory SS induction hood (I would expect even more on your car).
If this does not convince you, I would just remove the lower plate so you can put it back on when the weather cools down in a couple months.
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Steve
