SLP Underdrive pulley
Old Mar 23, 2006 | 06:34 PM
noblesramair's Avatar
Default SLP Underdrive pulley
A little while ago i bought an SLP underdrive pulley from someone here on the site but it didnt have the bolt. My question is can i just use the stock bolt or do i need to get the bolt that comes with the underdrive pulley?
Old Mar 23, 2006 | 06:44 PM
ILLWS6's Avatar
The bolt that comes with it isn't a special bolt, it's a new factory bolt.
Old Mar 23, 2006 | 06:52 PM
is it safe to just use the factory bolt thats already being used then?
Old Mar 23, 2006 | 07:42 PM
Z28LS1camaroguy's Avatar
nope you can only use the crank bolt once, you use it to tighten down the new pulley and take it back out then put the new one in and torque it to specs.
Old Mar 23, 2006 | 09:06 PM
okay thanks guys!
Old Mar 23, 2006 | 09:23 PM
SIC LSX's Avatar
yes you have to get a new bolt. If you get a ARP crank bolt you can reuse as much as you want what im going to do cuz i am going to be doing a cam install soon and then later i will get a pulley so i do no have to buy more then one bolt GM is about $8-$12 ARP is about $25 so im getting a ARP and be done with it
