Tts are ordered..questions on o2 extensions..??
Old Jul 12, 2002 | 01:29 AM
MY99TAWS6's Avatar
Default Tts are ordered..questions on o2 extensions..??
I think it says you can just move the factory harness and it will work..will it..or should I buy some extensions..if so how many..one for each side or do I need four for front and back 02's???
Old Jul 12, 2002 | 07:32 PM
Brother J's Avatar
Default Re: Tts are ordered..questions on o2 extensions..??
If you have the time and are handy with a soldering iron, try splicing in extentions to the wiring harnesses. I did that on 3 of the 4 O2 sensor harnesses with my TTS set up. Not all that hard, just takes time.
Old Jul 12, 2002 | 09:44 PM
y2kz28's Avatar
Yep, do what Brother J said. The stock ones definitey aren't long enough.
