just got back from first drive...
Old Mar 25, 2006 | 12:51 PM
purple98haz28's Avatar
Default just got back from first drive...
with my pacsetters. WOW. i have it just open headers with 18" extensions to save the o2's for now tds are in the future tho. well i took it to autozone to get codes scanned and i have a few probs. first- i am not showing a code for rear o2s but i have no sims in????? second i show code for coolant temp sensor. where is this? never showed this code before and third- 3/4 shift solenoid code. i had trouble getting the sensor wire back on when i was putting the tranny back in the car( fresh rebuild) but i think i can figure that one out. the car is fing nuts tho. so loud and with the fresh rebuild i loose traction going into 3rd again...been so long.
Old Mar 25, 2006 | 01:01 PM
kidkl's Avatar
My car didn't throw a code for the o2's for about 60 miles. Thats about all I can help you with.
Old Mar 25, 2006 | 01:10 PM
Ryan02SS's Avatar
Don't have the exact numbers on me but the PCM will test the rear 02's under certain conditions. Don't worry you'll see the SES light soon.
Old Mar 25, 2006 | 01:34 PM
LS69TA's Avatar
Yea, I drove for a while with no rear o2s and the SES light never came on. The coolant temp. sensor is on the driver side head at the front.
Old Mar 25, 2006 | 01:37 PM
thanks y'all
Old Mar 25, 2006 | 03:13 PM
Viper's Avatar
Yep coolant sensor is right next to plug # 1, almost in the way when you try and swap plugs.
Old Mar 25, 2006 | 05:03 PM
indyboom's Avatar
how is the 3rd-4th shifting?? Is it shifting? That bothers me, i have broken those damn things before..
Old Mar 25, 2006 | 07:24 PM
daryl2cb@yahoo.com's Avatar
my car took awhile as well to throw codes
Old Mar 25, 2006 | 08:02 PM
welli looked under the hood and the cts was unplugged. so i plugged it back in. as for the 3/4 shift sol. it shifts 3/4 fine. the sensor is pluged in but the " lock" would not lock so maybe that has somthing to do with less voltage?
