Air Lid & filter ?'s
Old Jul 16, 2002 | 10:25 PM
I8AFORD's Avatar
Default Air Lid & filter ?'s
Which lid flows the best. and filter
I would like to try the Holley and the clear MTI lid if it flows as good as the whisper and Direct Flo
Thanks
02 Z M6
Old Jul 16, 2002 | 10:32 PM
CR tuner's Avatar
Default Re: Air Lid & filter ?'s
To answer your question there is no flow difference between the MTI and the Whisper Lid we tested both lids and found them to be equal. We prefer MTI products so that choice is a good one. As far as the direct flow I don't believe there is much of a difference either, although we have tested it back to back with the others. Hopefully this helps
Thanks
Mike
Old Jul 16, 2002 | 10:36 PM
I8AFORD's Avatar
Ok thanks
Old Jul 16, 2002 | 10:41 PM
DARK AGE 53's Avatar
For the most part I think most lids flow the same, what you want is the lid that is built the best. I had a SLP lid which I thought was built stronger (as far as lids go) then most, and yes go with the Holley power shoot filter.
Old Jul 18, 2002 | 01:16 PM
WILWAXU's Avatar
All the lids perform nearly identical. Go with one YOU like the best, for price, looks or whatever.
