Loose hose after mod install
Old Jul 16, 2002 | 11:16 PM
01DetroitSS's Avatar
Default Loose hose after mod install
Went out to car today after just getting it back, and noticed a loud blowing noise. I popped the hood and found a 3/4 inch loose hose comming up from the front bottom off the drivers side.The hose is blowing alot off air out.The car is having a hard time getting a idle, it wants to stall out.I had a cam and headers installed along with custom tuning.
Old Jul 17, 2002 | 11:05 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: Loose hose after mod install
Sounds like the AIR pump hose. Is it the same one that snakes along the drivers side fender well?
Old Jul 17, 2002 | 11:11 AM
BadMonkey's Avatar
My thought exactly. Check along your fender wall there you should see where it goes. If its blowing anyway.
Old Jul 17, 2002 | 01:04 PM
LS1x2's Avatar
Formerly 4mulaJoe
Pull the air pump fuse out of put a breather on the hose.
Old Jul 18, 2002 | 12:48 AM
numbZ's Avatar
That is the AIR pump hose.It connects to the bottom side of the air box (air filter housing). <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
